 18v
Shane
las vegas
nv
Posted - 10/26/2006 :  14:00:09  Show Profile
if I wire up for 18v and run stock wheels is my son likely to fry the gears in the gearboxes rides on pavement mostly?
Posted - 10/26/2006 :  14:01:02  Show Profile
No.
JERSEYMIKE
Posted - 11/26/2006 :  06:48:09  Show Profile
so all You really have to do is wire a 12 and 6 or three sixes in series and find a place to mount them. No gear or motor mods are necessary for that kind of upgrade. I'm considering going from 12 to 18v to spice things up but am very much a begginer
Posted - 11/26/2006 :  07:23:22  Show Profile  Visit chopper's Homepage  Click to see chopper's MSN Messenger address
Yep, that's it...I've got two running 18volts and have done nothing else to them and they've worked fine all summer. Easiest/best mod for the money.
JERSEYMIKE
Posted - 11/26/2006 :  07:39:46  Show Profile
sounds easy enough. the only problem I foresee is finding a place to mount these things. Have you guys found it easier with the three 6's or a 12 and a six. Looking at some of these pics and diagrams Im getting the impression that 3 6s is more of a space saver.
Posted - 11/26/2006 :  08:02:50  Show Profile
Run three 6Vs. Using a 12V and a 6V together will eventually destroy the 12V battery.
JERSEYMIKE
Posted - 11/26/2006 :  08:30:41  Show Profile
very good to know. those thing arent cheap. thanks for all the help
Mudracer
Virginia
Posted - 11/30/2006 :  17:46:54  Show Profile
I spotted an 18 volt battery on the kidswheels.com page and was wondering what would be better the 18v or three 6v? It was a little more expensive than the gruber batteries. Mounting and wiring the battery is the only advantage I can think of. Which one would hold a charge longer? How long does it take for these sla batteries to lose charge during storage and what is the life expectancy?
Posted - 11/30/2006 :  18:29:13  Show Profile
Your biggest hurdle with an 18V battery is finding an 18V charger...
Mudracer
Virginia
Posted - 12/04/2006 :  05:21:27  Show Profile
Where is the best place to get a 6v 4 amp charger?
Posted - 12/04/2006 :  08:15:45  Show Profile  Visit chopper's Homepage  Click to see chopper's MSN Messenger address
Walmart...Schumacher, the charger is like $25 and it does 2,4,and 6 amps at 6 and 12volts.
nikg
Posted - 12/04/2006 :  17:51:26  Show Profile
Chopper...do you know which model it is and if most all the Wal Marts caryy this charger? I got the $17 model that charges at 1.5 Amps, but maybe I will get this one instead. Is it automatic? Is 2A per gruber battery too much? I have 3 6v Gruber 12ah that I was going to charge 12v(2 in series) and then 6v separately. If I could charge all three at once this would be better.
Posted - 12/05/2006 :  09:11:37  Show Profile  Visit chopper's Homepage  Click to see chopper's MSN Messenger address
Here is the charger
http://store.schumachermart.com/sc-600a.html
They sell it at walmart for $25. With that charger, you can charge all 3 6 volt batteries at the same time. Just hook them up parallel and charge them at 4amps (and yes it is auto shutoff). I do it all the time. If you want to do one at a time, just use the 2 amp setting. And keep that smaller charger you have, it's nice to be able to do multiple batteries at once.
