 24v scooter motor!!!!
Iam0014
semmes
al.
Posted - 10/21/2010 :  21:10:22  Show Profile
ok i know that the motor will work with out the controller, but will it work in the long run?? i got 4 scooters with 500w motors but all of the controllers are burnt up and i don't have the money to buy a new so will it hurt the motors in the long run to just use a relay?
Edited by - Iam0014 on 11/29/2010 14:28:29
ms1120
M-Town
Posted - 10/22/2010 :  08:35:02  Show Profile
Are you sure the controllers are burnt up? I thought I had a burnt one too till I read that they work from a push start on the scooters.
Iam0014
semmes
al.
Posted - 10/22/2010 :  12:22:25  Show Profile
yes i tried that one dose work well when i hook up the batteries it was wide open lol i guess i could just put a relay to turn the power on to it lol
Posted - 10/22/2010 :  13:32:58  Show Profile
Is this for a scooter or for a PW?
Iam0014
semmes
al.
Posted - 10/22/2010 :  18:38:51  Show Profile
sorry for a PW i am going to put two of the 500w in this
http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=19766
Posted - 10/23/2010 :  16:58:45  Show Profile
If you can't afford the controller how are you going to afford the sprockets, chain, etc? You are going to need very large sprockets on the wheel side. The scooter sprockets (wheel side) are going to be way too small. With such large tires I would be looking for as high a ratio as possible, at least 9 or 10 to 1.
Iam0014
semmes
al.
Posted - 10/23/2010 :  19:30:13  Show Profile
well the tires are really about the same size as the ones on the scooter,they are about 1.5" bigger, so i didn't think that it would be that much diff. and i have all of the stuff off the scooters, i have 4 whole, complete scooters with sprockets and chains. the tires are only 14.5" and roll really easy, it doesn't take much to move them, do you think that it will be that big of a diff? i don't really know anything about ratios so i need help on this?!?!???? lol
and not trying to be mean but no one has really answered the question.... well it hurt the motors to not use the controller??
Posted - 10/23/2010 :  22:05:42  Show Profile
But the scooters with 500 watt motors go 20mph+ and that's way too fast for a short wheelbase PW with no suspension. In reality you don't want to be going more than 10 or 12 mph at most.
If the wheels are 14.5" that means in one revolution they roll the vehicle forward 3.8' forward. If you want to go 10 mph, you need to travel 52,800' (in an hour). That becomes roughly 13,895 revolutions in an hour which is roughly 232 rpm's.
Your average scooter motor tops out at 2,500 rpm's so to reduce it down to 232 rpm's you need a 10.7 to 1 ratio. If the sprocket on the motor has 11 teeth you would need a wheel sprocket with 118 teeth. It's likely the sprocket you had on the scooter was only 60 teeth or so which will give you a theoretical top speed closer to 20 mph. Again, way too fast. And you will have the poor acceleration and lack of low end torque that scooters are notorious for.
But back to your original question, the motor itself will likely survive being used with just an on/off throttle, though you do have to worry somewhat about stalling the motor and burning it up. The bigger problem is that you are going to draw a huge amount of amps when you first apply power. That means you want at least 10 gauge wire to handle the load. And that also means that you are going to burn your way through some throttle and shifter switches eventually (maybe quite soon).
dozer
Milton
Posted - 10/24/2010 :  05:20:48  Show Profile
yes it will eventually hurt the motor. but the switches will burn first.
A motor is just coiled copper wire. with no resistors in it . When a motor is spinning the magnetic fields make the resistance.
If you were to unwind all the wire from a motor and hook power to it the wire would melt, fast.
Having no slow speed control and just dumping full battery volts across the motor when the motor is not turning, thats the same as unwinding all the wire inside.
Don't think outside the box.
Think outside the sphere that the box is floating in.
Posted - 10/24/2010 :  07:00:29  Show Profile
You could (since you have 4 scooters) use 2 sets of sprockets on each motor. You would need a intermediate shaft with one large gear and one small gear. One chain from motor to a large gear (intermediate shaft), another chain from small gear(intermediate shaft) to a large gear at the wheel. This would cut your ratio in half, cut the speed in half, double your torque, and reduce the chance of stalling the motor. The motor should work on a relay just like the P/W ones do. It will build more heat.
Iam0014
semmes
al.
Posted - 10/25/2010 :  16:25:22  Show Profile
ok didn't know that wow i may not do it any more lol i did count the teeth there is 11 teeth on the motor and 80 teeth on the sprocket don't know what that means tho lol
Iam0014
semmes
al.
Posted - 10/25/2010 :  16:27:57  Show Profile
i like that idea would it really help?? and what if i ran them at 12v, i don't have to do it i just had the motors so i thought i would use them... do you thank its even worth it??
Posted - 10/25/2010 :  16:40:29  Show Profile
The 80/11 will give you just under 8 to 1 ratio. I'm running that combination on my frankenbeast, which is very fast, and I'm only using 11" tires on it. With 14.5" tires that will increase speed significantly. You could try it.
At 12v it will have hardly any acceleration. 18v might be a better compromise.
Iam0014
semmes
al.
Posted - 10/27/2010 :  15:02:57  Show Profile
would it be wroth it?? i don't really want it faster, i thought that the bigger motors would have more torque.. i want it to have more power not necessarily more speed. would what taz said work??
Posted - 10/27/2010 :  23:11:01  Show Profile
Taz's idea would work great but it might be tough to get working right. Effectively you will be creating an open chain driven gearbox.
The "best" solution for massive torque would be a scooter motor with built in gear reduction. But that isn't what you own and you are trying to operate within a budget. A better budget solution would to trade for some MFJ gearbox/motors. They have great torque, handle overvolting and will work with the wheel drivers you already have in place.
Iam0014
semmes
al.
Posted - 11/28/2010 :  19:44:11  Show Profile
ok this is what i came up with
69.45 KB
71.39 KB
Iam0014
semmes
al.
Posted - 11/28/2010 :  19:45:36  Show Profile
it works i have tried it at 12v and it works good i am going to try it tomorrow at 24v and take a video for yall
Posted - 11/28/2010 :  20:11:20  Show Profile
This looks interesting. I think it's the first time this has been done...
Posted - 11/28/2010 :  20:24:35  Show Profile
do you have some type of spacers or washers to give the first gear you attached to some space so its not riding on the gearbox case? Just wondering how you are keeping it tight to the motor shaft but still able to float in the gearbox. More photos of how you did this would be appriciated.
ms1120
M-Town
Posted - 11/28/2010 :  21:42:54  Show Profile
Holy S$#%!!!!!!!!!!
Iam0014
semmes
al.
Posted - 11/28/2010 :  21:46:09  Show Profile
more to come tomorrow
Posted - 11/29/2010 :  07:38:44  Show Profile
I've thought about doing that kind of thing in the past but figured that gearbox flex would doom the project. Good luck.
Iam0014
semmes
al.
Posted - 11/29/2010 :  14:17:41  Show Profile
1st i had to drill out some holes
58.11 KB
56.64 KB
then i had to cut the gear in half
69.51 KB
with this
36.31 KB
then i took this screw out and used it to hold the gear box on to the motor
61.76 KB
like so
57.93 KB
Iam0014
semmes
al.
Posted - 11/29/2010 :  14:24:01  Show Profile
it hard to see in this pic but the are two washer under the gear
61.31 KB
Iam0014
semmes
al.
Posted - 11/29/2010 :  14:26:05  Show Profile
i know it the pic i put up last night i did not have the gear cut, i put the worng pic up thats was what i tried at 1st it did work but it wouldn't hold up
ms1120
M-Town
Posted - 11/29/2010 :  15:32:06  Show Profile
Ok, so wheres the viral video of these things in action? Im curious to see how they do in a car
Iam0014
semmes
al.
Posted - 11/29/2010 :  18:38:31  Show Profile
haven't got them in just yet still working on that but as soon as the are up and running a video with be posted
Iam0014
semmes
al.
Posted - 11/29/2010 :  18:54:55  Show Profile
ok this is what i got so far but every body on here knows how it goes one thing leads to another, i am going to add suspension..... i know i know lol, but if everything goes like i think it should be done tomorrow
59.38 KB
kickingrass
Everett
wa
Posted - 11/29/2010 :  20:01:03  Show Profile
HOLY $@#$ Batman!!!!!
If that works and the gearboxes survive, You could be the new Diety around here. :)
Posted - 11/29/2010 :  20:11:51  Show Profile
So...
What's the RPM of the motor?
Anyone have a tooth count for the missing gear?
Iam0014
semmes
al.
Posted - 11/29/2010 :  21:06:50  Show Profile
2500rpm and the gear i think has 62 teeth i only counted one time so may be off a lil
Iam0014
semmes
al.
Posted - 11/29/2010 :  21:11:11  Show Profile
this is what i am doing for suspension
43.36 KB
Iam0014
semmes
al.
Posted - 11/30/2010 :  18:21:01  Show Profile
sorry guys it rain all day didn't get to work on it today
Iam0014
semmes
al.
Posted - 11/30/2010 :  18:24:09  Show Profile
actually the truth is my wife is so amazing i just had to spend the whole day with her!
Iam0014
semmes
al.
Posted - 11/30/2010 :  18:25:43  Show Profile
ok the truth is my wife put that lol
Iam0014
semmes
al.
Posted - 11/30/2010 :  18:26:36  Show Profile
never leave some thing up when you get up even for a min lol but she is amazing
Posted - 12/01/2010 :  09:54:48  Show Profile
Iam0014
semmes
al.
Posted - 12/01/2010 :  18:46:43  Show Profile
i know she is crazy lol
i have to say i am sorry again, i started a new job to day i was not expecting them to call today because i did not have my uniform yet but they wanted me to start this morning, soooo what i am saying is it may be i lil while b4 i can get the jeep up and running for a video and to see if everything holds up. but as soon as i do i will have a video
Posted - 12/01/2010 :  18:56:51  Show Profile
OK, let's see - if that's a 62 tooth gear removed, and it had 21T gear, that's a factor of about 3...
So the 2500 RPM motors would be the same as a 7500 RPM motor. But stock motors run closer to 17K RPM if I remember correctly.
There will be a ton of torque, but I don't think there will be enough speed....
Iam0014
semmes
al.
Posted - 12/01/2010 :  19:08:19  Show Profile
well it 2500 at 24v how much would it be at 36v?? and i am not really to worry about the speed, i wanted a lot on torque in this one so it can go anywhere
so what would that make the gear ratio??
Iam0014
semmes
al.
Posted - 12/03/2010 :  21:45:29  Show Profile
ok got the motors and axle back in tonight ran a test at 12v (the battery was not fully charged) it ran at walking speed and then i put some weight on it, my weight, 215lb... it never slowed down any!! another thing when i started taking the what i thought were shocks will they are fake... :( but i put them on there anyhow just for looks.
well here is what i have so far
40.52 KB
60.17 KB
Iam0014
semmes
al.
Posted - 12/05/2010 :  11:20:37  Show Profile
ok after a few more test runs i have found that this will not work. i nut backs it self off so i am going to have to get a gear with a set screw in it
44.37 KB
Iam0014
semmes
al.
Posted - 12/08/2010 :  17:50:56  Show Profile
man everytime i get on the computer this website is up..he is never going to learn i guess...ins't my hubby sooo talented??=)
Iam0014
semmes
al.
Posted - 12/08/2010 :  17:55:15  Show Profile
man every time i get on the computer this website is up..he is never going to learn i guess...ins't my hubby sooo talented??=)
isn't't my wife crazy but i love her!
sea_stork
Ocean Springs
MS
Posted - 12/08/2010 :  18:14:06  Show Profile
If you can get one thread showing past the nut, you can tap a dent in the thread to stop it from backing off.
Dodge Charger Hemi Police Cruiser
Monster Sounds Bigfoot F150
Burgundy Escalade EXT
F150 Monster Traction
MT Yamaha Raptor 700R (3)
Barbie Jammin' Jeep
Barbie Jammin' Jeep reconditioned into a green lifted Jeep (The Bullfrog)
Silver Lil F150 ( 12V)
Firerock Jeep (12v)
Barbie Dune Beetle
Lil Tykes Yellow Hummer H2
Peg Perego Gator 4x2
Step2 Mighty Mac (project)
Peg Perego Gator 4x2 (parts)
"Damn the torpedoes, full speed ahead..."
Iam0014
semmes
al.
Posted - 12/08/2010 :  18:44:54  Show Profile
thats a good idea but they fell off some where in the yard and have not been able to find them they were rev. thread too so i ether have to buy new ones or get set screw gear
Neo-PW
jersey
Posted - 12/09/2010 :  11:51:24  Show Profile
Garbage day is great for finding used peices.
Iam0014
semmes
al.
Posted - 12/10/2010 :  20:52:15  Show Profile
ok this is a video of when i 1st put the motor in
i know every one is waiting to see how they work in the jeep but i have to wait to get the gears with set screws
Iam0014
semmes
al.
Posted - 12/10/2010 :  20:54:02  Show Profile
it is a lot quieter the the stock motors
Iam0014
semmes
al.
Posted - 12/18/2010 :  21:30:33  Show Profile
and the rest of the story
http://forum.modifiedpowerwheels.com/viewtopic.php?f=9&t=71
