 Wiring two 6 V and one 12 V
rx8power
Posted - 09/25/2010 :  05:57:42  Show Profile
Hi
I want to wire two 6 Volt batteries and one 12 Volt batterie.
My idea is to wire the two 6V in line to get 12V and then wire them parallel to the 12V batterie.
My problem is that i want to put a switch in the car to switch from 12V to 18V.
So i must wire the two 6V parallel and then in line to the 12V batterie.
Can somebody give me a wiring diagramm for this?
Regards
Stephan
Posted - 09/25/2010 :  07:33:18  Show Profile
I see lots of relays in your future. Divinar or Jpartham should be along sometime with a drawing with about half a dozen relays. To do what you want.
rx8power
Posted - 11/20/2010 :  14:46:16  Show Profile
Its done.
I need 7 relays to switch between the two 6 V in line to the 12 V parallel, and the 6 V parallel in line to the 12 V to get 18 V.
It works very well.
I even build a key switch in the wiring to disconnect the wiring.
Regards
Stephan
Posted - 11/20/2010 :  18:40:14  Show Profile
LOL - I missed this first time around.
Originally posted by rx8power
Its done.
It works very well.
Regards
Stephan
Awesome!
Can you post some pics?
rx8power
Posted - 12/12/2010 :  06:52:58  Show Profile
Here a few pics.
I installed the 12 V Battery in the front and two 6 V Batteries in the back between the engines.
Edited by - Divinar on 12/12/2010 10:24:57
Posted - 12/12/2010 :  10:25:02  Show Profile
I hope you don't mind, I edited your links to make them work. (You left out the quotes around the URL part)
Edited by - Divinar on 12/12/2010 10:25:27
rx8power
Posted - 12/12/2010 :  10:28:17  Show Profile
Thank you.
