way7837
Fairfield CA USA
14 Posts |
Posted - 09/19/2010 : 13:42:20
I just picked up a used Nascar 12v Tony Stewart. It's bone stock and my son is having traction problems because of our terrain. My driveway has an uphill incline and the court we live in also has a slight incline. The stock Nascar tire does seem a bit worn from the previous owner, but it doesn't look too bad. Can someone give me a recommendation for traction? Should I get new stock tires?
Regards, Waylon |
Ryum
32 Posts |
Posted - 09/20/2010 : 19:22:20
http://www.wonderhowto.com/how-to-install-traction-bands-onto-power-wheels-tires-264365/
is a how to I found on this subject on adding traction to a power wheel. The reason I was looking into traction for a power wheel is most of the videos I have seen where someone increases the speed by changing the battery seem to really increase the spinout, but the acceleration seems to suffer, and the tires seem to take more damage from fishtailing, and drift turns.
I saw one video where they increased a lightning mcqueen car to 21 volts and it looked like you had to give the car a push for it to actually start going forward.
What I don't know is if the "grab" of these bands would damage the motor... since it is basically on or off the added traction could be pretty bad for it. If there was a way to more slowly speed up to top speed that is where these bands would probably help the most, and have less possibility to cause harm.
Hopefully someone here with some experience on this will give their experience on this issue as I am just guessing. |
Skiatook OK USA
2622 Posts |
Posted - 09/20/2010 : 20:31:58
| Traction dosen't hurt the motor it hurts the gearboxes. The spining out is actually saving them from the harsh pounding of locking up as soon as the kit kid hits the pedal. Best solution teach kids to start out in low then shift to high once rolling. |
Please sign up at new version of forum at http://forum.modifiedpowerwheels.com/ complexity is the enemy of reliability |
Ryum
32 Posts |
Posted - 09/20/2010 : 23:40:56
| That might work for way's but mine doesn't have a "low gear" |
way7837
Fairfield CA USA
14 Posts |
Posted - 09/21/2010 : 10:00:25
| I need to find a solution. Our streets right outside my house has a slope. My son is riding a stock 12v Nascar. It won't even go uphill. The tires just keep on spinning. I can't upgrade it to 18v, it will make the matter worst. Any other ideas? |
Lino Lakes MN USA
1589 Posts |
Ryum
32 Posts |
Posted - 09/22/2010 : 00:45:34
Are any of these the kind of gearbox that a super6 uses? http://mltoyz.com/zencart/index.php?main_page=index&cPath=1_8&zenid=pljs7mbhorv2a5arcqnc4gnup5
and if not can anyone link a place that sells the right ones? If the gearboxes are really around 13 bucks I might just order a used one and use it with some traction bands and see how it goes then if it does noticeable damage too soon then will scrap the traction band idea, but if it's more than a couple of months that seems like a decent cost for the traction.
All of this is dependent on how much spin out I see when I do go from 6v to dual 6v or 12v, but I'd like to be prepared since seeing those youtube videos of the lightning mcqueen that needed a push to get going cause it was spinning out so much. |
Meridianville AL (35759) USA
631 Posts |
San Jose 95123 CA USA
3057 Posts |
Posted - 09/22/2010 : 09:57:14
You'll have to open it up and look - the Lightning McQueen had 19T #7 gearboxes stock, both 12v and Super6. Not sure on the Nascar, I didn't have one, but it's the same basic body and wheels, so it's likely the same gearboxes.
Fortunately, 19T's are common (they're in the non-lifted unibody Jeeps) |
Escalade (Rubber tires, LED lights, Key switch, Remote Kill, wings. Wings?) Lil Wrangler (2WD, 12v, Lights), Dora Jeep (Super-6 @ 12v, lights), Jeep Enforcer turned Aftershock (18v, WIP), Grape Gaucho A151 (24v, scooter controller, WIP)
Kawasaki Mojave 250 (Stock), PP Gator (Lights), Home Depot Loader, Lightning McQueen (Stock) |
bader
furulund Sweden
36 Posts |
bader
furulund Sweden
36 Posts |
lawfirmgwc
Hewitt TX USA
3 Posts |
Posted - 11/03/2010 : 15:29:42
| Has anyone tried using a cut up soaker hose as a way for extra traction? I was thinking that since soaker hoses are often made from recycled vehicle tires they might be an excellent way to get Power Wheel traction for cheap. I was thinking you could cut the hose, then wrap the tire and secure it to the tire using RTV silicone and perhaps some screws or rivets. |
(77627) Nederland Texas USA
2272 Posts |
Posted - 11/03/2010 : 16:35:47
I've never heard of anybody trying that, but it sounds like a good idea! I'm sure plenty of us have soaker hoses that spray us when we turn the water on , and having a fairly thin contact patch may not slow the wheels down as much on hard surfaces as the wider ones...? |
