 #3 gearbox grinding FIX...(my attempt)
Posted - 07/29/2010 :  18:52:15  Show Profile
Once again I had another pile of broken stuff. After the success of my plastic pinion fix, I decided to tackle 2 of the many grinding #3 gearboxes I had.
This will not fix broken teeth, but I find that most of the gearboxes had good gears.....but they made horrible noise on startup.
The problem appears to be that the case spreads under load and the axle pin for the center gear hops out of its locating hole. The hole may appear tappered or egg shaped after time.
51.43 KB
I removed the stock pin and installed a 1/4 inch X 1-1/2 inch shoulder bolt (Fastenal) and a lock nut. I redrilled the gear to a 1/4 hole. Run the drill though the gear several times untill it spins free on the bolt. If it fits too tight there will be no room for grease (don't go crazy on it). Then drill out the case holes to 1/4 inch also(these can fit snug) so the bolt passes through the case. After reassembly, install a lock nut on the shoulder bolt. this will stop the case from spreading.
I put my first test set in a 12v super 6 quad today and the farting/grinding noise is gone. (This set wouldn't even move with a heavy kid in tow) The only question now is durabilty....time will tell. I'm off to Fastenal tomorrow for more bolts. I will take some pics of this set as I go. Updates and detailed pics to come soon.
Dylan13
Oakmont
Pa
Posted - 07/29/2010 :  19:00:41  Show Profile
I always wondered what that awful noise was You gotta get some pics of the finished product
Super Power Gaucho
Peg Gaucho - John Deere Makeover
Peg Gaucho / Peg Gator / Peg Buck Quad
Hot Wheels Lambo - 12v
Enforcer Jr. - 2WD Super 6 - 12v
'lil Sport Barbie - 2WD High/Low rewire
Barbie Dune Beetle / Police Harley / Red Harley
Posted - 07/29/2010 :  19:10:05  Show Profile
Yup...I'll take pics of the set I'm working on now.....I wanted to make sure they worked....... ahhh who am I kidding....just to lazy to get the camera the first time
Posted - 07/29/2010 :  19:50:35  Show Profile
I don't know about yours but my fastenal would only sell me shoulder bolts by the box of 25. It was almost 30 bucks for a box. I Searched on Amazon and small parts inc sells them cheap. I got 1/4 x 5/8 and 1/4 x 3/4 from amazon one was 6 bucks for a pack of 25 and the other was 3 bucks for a pack of 25 so they are the way to go once you find the size you need. The 1/4 x 5/8 are perfect size for drilling out the front Axel holder rivets and replacing them with the shoulder bolts to remove the slop.
Posted - 07/30/2010 :  05:15:55  Show Profile
Yeah, they told me that also. I told him I only needed 2 for an experiment...if it worked I would buy lots more. When he entered the part number it gave him an individual price, so he sold me 2. I may buy the whole box now, so I can sell a few if you need them.
hypo21
Bangor
Posted - 07/30/2010 :  06:48:29  Show Profile  Send hypo21 a Yahoo! Message
I will be doign this Sunday to the big foot with the same set up super 6's and #3s.
Thanks for the help on this one Taz!!
Getting there... This is just too addicting. Love it.
Posted - 07/30/2010 :  07:00:39  Show Profile
Here is a link to the bolt. This is for a box of 25, but atleast you have the dimensions.
http://www.fastenal.com/web/products/detail.ex?sku=1126308&ucst=t
Posted - 08/07/2010 :  19:23:20  Show Profile
Better late than never.
The hardest part is drilling the gear. The plastic is so soft, it expands and the hole ends up being smaller than intended. The gear MUST spin free on the bolt for proper lubrication. I had to drill this one many times before it was loose enough.
Here are a few pics of the bolt install.
51.46 KB
47.01 KB
45.95 KB
ttommyb86
peoria
illinois
Posted - 08/07/2010 :  20:20:33  Show Profile
So what was the final size bit used?
one man gathers what another man spills
Posted - 08/08/2010 :  04:47:06  Show Profile
1/4 inch. I just kept running it through. The next size up (in my set) is too big.
Starwriter
Springfield
OR
Posted - 08/08/2010 :  08:09:27  Show Profile
If you get a size F drill bit, it's .257".
Posted - 08/31/2010 :  08:35:38  Show Profile
Taz I got a set of 3b GB that some of the teeth are slipping a bit but the teeth show some wear in spots and look like they are folding plastic to one side. Do you think its worth trying this or just junk them?
Posted - 08/31/2010 :  08:54:06  Show Profile
I have not tried that yet. I would guess that if you have atleast 1/2 the tooth left, it could work. I'm 99% that the tooth was damaged while the case was deflecting. If you try it, please post the results.
Posted - 08/31/2010 :  14:08:32  Show Profile
Ok well I am going to have to round up some shoulder bolts that long. Will update you once I try it.
Posted - 09/24/2010 :  03:07:50  Show Profile
How did this work out?
I tried this on a customers quad last night. It had 2 teeth that were rounded over on the last gear. In another spot it had a tooth that resembled a healthy speed bump. It fixed the the rounded gear skip. As far as the completely hammered tooth......That runs great too as long as the quad doesn't stop on that tooth. A high torque restart will cause a brief grunt. Under normal driving.....no noise at all.
Posted - 09/24/2010 :  05:29:01  Show Profile
Taz I haven't installed them yet. Right now everything I have has good gb in them. So I was going to wait until got something needing gb to try it out. I will let you know when I do try it out.
ms1120
M-Town
Posted - 09/24/2010 :  13:29:19  Show Profile
Hey, since you arent doing anything else at the moment, can we send you our damaged or wayward gearboxes and you fix em? lol
Posted - 09/24/2010 :  13:59:17  Show Profile
Are you talking to me or Taz?
Posted - 09/24/2010 :  14:17:55  Show Profile
Hey sure.....send 'em. $25 each and I'll send'em back! LOL...........JK
ms1120
M-Town
Posted - 09/24/2010 :  14:42:44  Show Profile
Sorry Blake for the confusion. I was talking to Taz since hes sitting around the house after trying to hack his finger off. lol. Much love Taz. Get better soon so you can finish the fire truck
Posted - 09/24/2010 :  14:54:47  Show Profile
THANKS
I've been tinkering with the fire truck......just nothing to post. If you've seen one wire....you've seen them all. I see them in my sleep! The finger is stiff...but starting to work again
Posted - 09/24/2010 :  15:08:53  Show Profile
I can beat that deal - For just $10 each, I won't send them back!
Posted - 09/24/2010 :  15:10:40  Show Profile  Visit chozian's Homepage
What a steal!
rolfvanrijn
Indianapolis
Indiana
Posted - 10/03/2010 :  18:54:50  Show Profile
How are your gearboxes holding up after your fix
12v Barbie Jeep --> Black Jeep, LED lights, Horn, Backup Beeper,Sirene.
Yamaha Quad 12v-18v
