 Speed for F150 6v
toadismcg
Posted - 03/26/2010 :  13:31:29  Show Profile
Hello all! New guy here. I am interested in giving my son’s F150 a little more speed. It currently only has forward and reverse. I’ve been reading the forums for days prior to posting since I hate to ask an ill-informed question, but here I go anyway.
It sounds like all I need to do is get a 12v batter, cut off the connectors and wire a 30amp fuse on the positive side then wire what is left into the old batter connector. Is that correct?
What about charging? Can I use the same charger?
Also what is the importance of the amph? Is it voltage or amph that gives me the speed?
Mr. Lynch
Renton
Wa
Posted - 03/26/2010 :  13:37:27  Show Profile
If your current 6v red battery is good, just add a 2nd one. The super6 vehicles on 12v go pretty fast and my kids love them.
The voltage is what gives you speed, the "AH" is what gives you drive time.
Working:
Super6 Jazzy Jeep (12v), Super6 Trail Rider (12v), Barbie Escalade (BMX tires), Lil people Tot Rod
Peg Santa Fe Train (6v)
Projects:
Jeep Wrangler Limited, Escalade (Seahawk theme), Metal Frame Jeep Sahari
toadismcg
Posted - 03/26/2010 :  15:04:41  Show Profile
Do I still need a fuse if I use that type of wiring?
Also how can I test my current battery?
Posted - 03/26/2010 :  20:30:28  Show Profile  Visit gseric69's Homepage
If you use stock PW batteries, you don't need to add a fuse. If you use aftermarket batteries, you must add a fuse.
A volt meter is a good way to test your battery. They aren't that expensive.
sleepy23
Maryville
TN
Posted - 04/15/2010 :  09:15:03  Show Profile
how big is the seating area of the 6v f150? could the seat be pused all the way ack to the tailgate to seat a larger body?
Mustang GTR: http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=16343
F-150 Super Snake: http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=16824
F150 Raptor: http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=18071
Posted - 04/15/2010 :  09:25:19  Show Profile
It depends on which generation of F-150 you have. The ones my kids had (2nd generation) did have two seat positions but even with the seat back it got tight on space at 5 or 6 years old.
sleepy23
Maryville
TN
Posted - 04/30/2010 :  07:58:23  Show Profile
What about 12v and upgraded motors in a super6 such as the f150?
sleepy23
Maryville
TN
Posted - 05/18/2010 :  06:09:56  Show Profile
Anyone ever figure out the speed for a 12v super6 f150?
rockjessemax
mayfield
kentucky
Posted - 05/22/2010 :  06:09:43  Show Profile
Maybe I missed it but adding a second 6v for speed, the 2 6v will have to be wired in series to create 12v. The wiring and motors in the f150 should be OK. As for the seat...I cut the rear/lower part of the seat base off and that allowed me to move the seat rearward. Not too much or you will expose the the lower compartment to the weather.
You can't use the stock 6v charger to charge a single 12v but you can use it to charge the 2 6v. Just hook them up in parallel and charge them both at the same time.
Transporter of:
"LIBERTY BELL 7"
I LIVE IN A BATTERY POWERED WORLD
eclipsed95
Romney
WV
Posted - 05/22/2010 :  18:48:15  Show Profile
I switched the connector of our F150 to the 12V end and it's quick on 12 volts. We've had great luck with getting speed out of the super 6's. We currently run super 6/12 volts on our F150, Dora Jeep, Big Foot, and Big Jake. All single seaters, but they're light and go fast.
About 20 of these things and counting!
Yeah, it's a little addicting.....
sleepy23
Maryville
TN
Posted - 05/26/2010 :  07:31:19  Show Profile
So maybe 7-8mph?
PW ChopShop
Memphis
TN
Posted - 05/26/2010 :  12:04:06  Show Profile
Originally posted by sleepy23
So maybe 7-8mph?
My GPS gives a top speed reading of 6.7 to 7.2MPH on Two different Super6 rides. I would put average speed of a Super 6 at 12V a shade under 7MPH.
sleepy23
Maryville
TN
Posted - 05/26/2010 :  13:36:09  Show Profile
Thanks. That helps me establish a baseline for my upgrades
eclipsed95
Romney
WV
Posted - 05/26/2010 :  19:11:54  Show Profile
If the stock 12v pw's go 5, then 7mph sounds about right.
v8280z
Mesa
Posted - 05/27/2010 :  19:29:05  Show Profile
I put a 12v 8AH Gruber battery in our 6v F150 and it is as fast as the 18v Lambo with Titan 550 motors. The only problem is that it is so light in the rear it spins the tires like crazy! My 6yo loves to do doughnuts with it!
18v Lamborghini (MP3, Lights, gauges, water cannon)
12v F-150 (super 6 motors, lights, remote kill switch)
12v Jeep (super 6 motors, lights)
12v Lil Quad
sleepy23
Maryville
TN
Posted - 05/27/2010 :  20:00:26  Show Profile
wow, i cant wait to get my truck done to see what it does.
aztracks
Chandler
Arizona
Posted - 06/01/2010 :  12:18:35  Show Profile
I just put 12V in our F150 and it was pretty fast. I didn't intend to make a project out of this one but couldn't resist. I'll get a speed reading on it soon to provide another data point.
Wire and motors were warm but not hot after 45 minutes of operation on a warm day.
I didn't do anything but put another battery in but I am probably going to make it two speed with slow reverse. My son popped it directly into reverse and blew the 30A fuse I had inline.
F-150:
'94 Super Sound Jeep Sand Blaster : http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=17274
Edited by - aztracks on 06/01/2010 12:20:40
sleepy23
Maryville
TN
Posted - 06/01/2010 :  15:51:55  Show Profile
That would be awesome to know. I have a radar gun I can check ours with once I finally get it done.
aztracks
Chandler
Arizona
Posted - 06/01/2010 :  17:03:28  Show Profile
That isn't the Hotwheels radar gun by chance is it? I bought one of those a couple of years ago for about $30 but now I see them selling for $80.
http://www.amazon.com/Mattel-J2358-Hot-Wheels-Radar/dp/B000EHLB0M/ref=sr_1_1?ie=UTF8&s=toys-and-games&qid=1275436965&sr=8-1
F-150:
sleepy23
Maryville
TN
Posted - 06/01/2010 :  19:00:38  Show Profile
nope, mine is a bushnell or something...???
sleepy23
Maryville
TN
Posted - 06/02/2010 :  05:59:05  Show Profile
Math says our truck should run about 11.5 mph. That seems a little slow.
sssrip
Churchton
MD
Posted - 06/02/2010 :  06:14:32  Show Profile  Send sssrip a Yahoo! Message
"If your current 6v red battery is good, just add a 2nd one"
Anybody of have a picture of a super 6 wired like this for more speed or point me in the direction of one. Pictures are much easier for me to understand.
Super6 Fire Truck
Gator
Big Jake
Cat Skid Steer
aztracks
Chandler
Arizona
Posted - 06/03/2010 :  00:11:48  Show Profile
I didn't intend to make a project out of this one but I couldn't help myself. Currently it simply has 2 6V batteries installed in series using quick connect terminals (with electrical tape over them). I plan to make a more permanent setup and use thicker wire.
Here is where I cut the hole and used some rivets and webbing to make a new battery spot. I used a dremel tool and the hole is just big enough.
Here is what I use to hold the battery. I have a Werker battery and a power wheels battery in this vehicle. It fits in snug. When I redo it I'll probably put some kind of a strap over both batteries, but they are pretty well secured for now.
66.84 KB
F-150:
Edited by - aztracks on 06/03/2010 00:22:11
sleepy23
Maryville
TN
Posted - 06/03/2010 :  04:26:01  Show Profile
One dude used a plastic electrical outlet box and grafted it in as a battery tray.
aztracks
Chandler
Arizona
Posted - 06/04/2010 :  00:09:27  Show Profile
I took some measurements with my F150 running on pavement using GPS and a current clamp meter.
Running 6V (6.5 unloaded)
2.8 mph pulling 5.2A
Running 12V (13.08 unloaded)
6.5 mph pulling 10.0A
So it looks like it more than doubled. I took some other current measurements but I'll put them in another post.
F-150:
sleepy23
Maryville
TN
Posted - 06/07/2010 :  04:30:22  Show Profile
That's interesting. That is on super6 motors?
aztracks
Chandler
Arizona
Posted - 06/07/2010 :  14:27:04  Show Profile
It's stock and I'm pretty sure it's super6 motors. It's a 1 seater F150 that we bought new last November and it ran 6V stock, with only forward and reverse.
F-150:
sleepy23
Maryville
TN
Posted - 06/30/2010 :  13:10:23  Show Profile
So I put the other super6 on 12v and that thing does move.
Posted - 09/10/2010 :  05:16:48  Show Profile
Originally posted by siliumang
this is a little hard for me~
can I get some eggs with my spam? Also hashbrowns and biscuit and gravy please.
Posted - 09/10/2010 :  15:21:13  Show Profile
Deleted!
Ryum
Posted - 09/20/2010 :  17:56:46  Show Profile
The pictures aztracks posted helped, but I don't really understand this set up yet.
What changes do you make to the stock fischer price 6v battery so that another 6v can be added to it?
I do like with that set up you still use the original connection that runs to the motor. What are the pros and cons of using
one 12v battery vs two 6 volt batteries with one of them being the original stock battery?
I have seen a video on how to take out the connector in a bad fisher price battery, but not how to modify a working one like this.
sleepy23
Maryville
TN
Posted - 11/27/2010 :  21:05:49  Show Profile
I am considering dropping 21t gearboxes into a little super6 and running those with overvolted super6 motors.
sleepy23
Maryville
TN
Posted - 12/11/2010 :  18:48:22  Show Profile
well, i can tell you that a HPI550 GT with 21t boxes is slightly slower than an overvolted super6 setup
