 My unibody jeep sag fix
dasilva100
Kitchener
ON
Posted - 03/15/2010 :  06:24:27  Show Profile
I sold the jeep last friday and I wanted to fix the slag before the buyer pick it up. So as I don't have special tools to make custom metalic pieces, this is what I did with some things I bought at Home Depot (I didn't spent more than $15)
I used a metalic perforated piece and I cut 2x 3holes pieces and 4x 2holes pieces. For the three holes pieces I made a hole bigger for the axel using the drill
53.32 KB
I used 2x 2holes pieces as washers
53.29 KB
53.95 KB
68.05 KB
Here is the most important step: the holes to put the screws to fit the upper metalic pieces (three holes), have to be made as closer as possible to the outside in order to maintain the axels in a good (to inside) position to reduce the slag.
54.43 KB
Two wire rope clips to maintain this metallic piece in place:
42.86 KB
Two more two holes pieces as washers for the clips:
53.43 KB
48.69 KB
Before:
After:
82.15 KB
Hope this help. Can be taken as sticky?
Edited by - gseric69 on 06/06/2010 19:25:11
Delhi
Posted - 03/15/2010 :  07:04:01  Show Profile  Visit hotrodtodd's Homepage
Nice fix
Bigfoot
Worksite Gator
Driveway Racer
Handy Manny 6v quad
Posted - 03/16/2010 :  17:27:09  Show Profile  Visit gseric69's Homepage
Nice work,
I was thinking about adding your info to the Front End Alignment FAQ
http://modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=1144
dasilva100
Kitchener
ON
Posted - 03/17/2010 :  06:45:25  Show Profile
Thanks Erik, If you want to add a link or copy the post to the FAQ, go ahead.
Modmom32
Cookeville
Posted - 06/04/2010 :  07:57:47  Show Profile  Visit Modmom32's Homepage
I admit, at 1st I was like what? but I applies it to my actual jeep and saw it needed a spacer to tighten up areas in there and then I came back to the pics and saw that was what you did and for stability you braced both sides up. Great idea. I want to unit to look more stock so I really didn't want to weld. but I would it I thought it would work and keep its structural integrity.
*arctic Shark snowmobile (beng modified again, scooter) but works!
*indianaJones Harley *desert bike *desert Challenger street bike *saftey 1st Chopper *SF viper*Herbie fully loaded via remote 12v....18v if lucky *gravedigger *mx350 *john deer tractor( still his favorite) *blue flame bigfoot *A151 * qty 2 twin 700* mx3 trike n 2 powerrider nascars (DALE SR n used to be #24 now General Lee) SOLD> 12v herbie
AMY
Posted - 06/06/2010 :  19:24:11  Show Profile  Visit gseric69's Homepage
Well, it only took 3 months, but I finally got it added.
dasilva100
Kitchener
ON
Posted - 06/07/2010 :  07:08:42  Show Profile
WoW! that was fast!
Hope this fix helps other people to fix their PW's
