Atarah
Stockbridge Georgia USA
3 Posts |
Posted - 02/26/2010 : 20:07:01
| Okay, I read the posts about the Escalade not getting enough traction. Okay, it's true. I already purchased one though. Problem is it is horrible on my grass. I purchased it from someone whose children rode it on cement so the traction is really bad. Now what should I do to make it have better traction on my grass? By reading the posts I can't put BMX bike tires on them, the'll just make them go slower and if I were to modify the tires someway I would destroy the gears. Any suggestions? |
Atarah |
Red Lion PA USA
6315 Posts |
Posted - 02/26/2010 : 20:45:13
Take a look at the treads Taz11 did on his Jeep. It's true that any traction aid is going to be putting more strain on the gearboxes, but if you're just looking for more traction right now, I don't think it's going to be too detrimental. One easy mod you could do is to put a larger resistor on the brake wire (or if there isn't one, to add one) this will reduce the abrupt autobraking, and reduce the gearbox strain by a good margin.
If you start modding for more speed, then you'll probably need to start working on ways to help with the strain even more, such as a scooter controller or Fortis' spring return setup. |
36V Peg Perego Apache - Project: Super Power Police Jeep, 18V Metal Frame Jeep - Project: Sarge Dragon/Craftsman Pickup Hybrid (WIP), 18V John Deere Off Road 4x4 (Gaucho, SOLD!) 12V Lil Jeep, 18V Turbo Sun Jammer Jeep, 12V Super 6 F150 Blue Thunder, 18V Lightning McQueen & 12V Lightning McQueen w/Duratrax Motors (Sold) 18V Green & Blue Ninja Quads w/19T's, 18V Dora Quad with 21T's 12V Harley Bat Bike w/Duratrax Motors, 12V Pink Harley (Future Trike) Future Builds: 12V Xtreme Machine, 12V PW Fire Truck, 6V Wild Thing Super 6 & Mach 5 RIP: 12V Super 6 Suzuki Quad w/Seperate Brake pedal (Decommissioned/Parted) |
Mr. Lynch
Renton Wa USA
102 Posts |
Posted - 02/26/2010 : 23:19:09
My backyard is 100% grass with a slight slope in one area, so I put Mt. Bike tire tread on my Escalade wheels. It works great and handles the grass fine. If my kids run into something and keep the power on, the wheels do still slip a bit and if the grass is wet there is a little wheels spin too. Without the Mt. bike tires the Escalade was pretty worthless in the grass if it was anything other than bone dry and mowed really short. Getting your kid unstuck gets old real fast. Adding the Mt. bike tires was totally worth it to me.
On the street, the Escalade is 100x quieter now. Those wide plastic tires are crazy loud. |
Working: Super6 Jazzy Jeep (12v), Super6 Trail Rider (12v), Barbie Escalade (BMX tires), Lil people Tot Rod Peg Santa Fe Train (6v) Projects: Jeep Wrangler Limited, Escalade (Seahawk theme), Metal Frame Jeep Sahari |
Atarah
3 Posts |
Posted - 02/27/2010 : 22:16:43
| @ Mr. Lynch, I read on here if you put those BMX tires on them for grass then it actually makes your car go slower. I don't know. and @ gseric69, I have no idea how to put a resistor on the car although I would love to. Any ideas? |
Atarah |
Mr. Lynch
Renton Wa USA
102 Posts |
Posted - 02/28/2010 : 16:31:46
I wouldn't say it is slower when you consider with BMX tires it goes, without it gets stuck! If it is slower overall, it isn't by much. If stock is 5mph, then bmx tires maybe drop it to 4.5mph. It turns way better and can make it up the slight incline in my yard without getting stuck though. Both my super6 Quad and Jeep are running 12v and are much faster than the Escalade, but they do get stuck alot since they have the stock plastic tires.
Red Lion PA USA
6315 Posts |
Posted - 03/01/2010 : 12:51:28
Take a look at the diagram on the left here. This is how the wiring in your Escalade is set up. It shows a wire coming off the throttle switch with a resistor on it. This isn't on every car, so if yours doesn't have one, then adding on will help soften the braking. The wire it's on is typically orange.
I beleive the stock size typically used is 5 Watt .22 Ohm, but you can go up to a 5 Watt .47 or .51 Ohm resistor to soften it even more.
Edited by - gseric69 on 03/01/2010 12:54:15 |
Atarah
3 Posts |
Posted - 03/01/2010 : 16:14:14
| Thank both of you for your replies. I will look into making these changes and thanks for the diagram. |
Atarah |
SmittyTuck
El Cajon CA USA
16 Posts |
Posted - 12/09/2010 : 17:34:34
| Gseric69..Where would could I find one of these resistor? My daughters caddy has a horrible skid when she lets her foot up, Also my drive way is on a bit of a incline, if I rewire her ride to a larger gauge wire would it help and get a bit more power? Thank you! |
