 Lil Jeep x 2
Dylan13
Oakmont
Pa
Posted - 02/22/2010 :  18:23:39  Show Profile
Finally got around to working on these two today. A little work in the garage, then inside.
I ended up putting the 2 gearboxes from the Big Jake in the Enforcer and the Barbie got its original. Only problem was the axle from the Jake was bent, now with a shortened 2 seat jeep axle fitted on the Jr., the left gearbox/tire wobbles - the axle is straight, could one of the gears inside cause a wobble I ran out of time to get it torn apart....And I took a little from Taz's lil jeep and kept the Jake drivers to add a bit more width to the rear on the Enforcer - not much but enough
Started to do a complete rewire, at least on the barbie - its for my niece and she needs the high/low, Dylan on the other hand is good so I think I'm just going to toss in the Jake harness, little less headache, not to mention waste
I'll get some pics later but there really isn't too much to notice
Super Power Gaucho
Peg Gaucho - John Deere Makeover
Peg Gaucho / Peg Gator / Peg Buck Quad
Hot Wheels Lambo - 12v
Enforcer Jr. - 2WD Super 6 - 12v
'lil Sport Barbie - 2WD High/Low rewire
Barbie Dune Beetle / Police Harley / Red Harley
Posted - 02/22/2010 :  20:02:49  Show Profile
If your keeping the Big Jake super6 motors you may want a hi/low switch. They get a little hard to park when they do major burnouts every time you hit the pedal. Look forward to seeing pics.
Dylan13
Oakmont
Pa
Posted - 02/22/2010 :  21:05:35  Show Profile
I know what you mean, he loves his super6 quad and I hated to get rid of the Firerock we had.....
Well I ended up getting the barbie wired up tonight. Guess it was a bit easier than I had thought, just had to modify some of the spade connectors. I haven't hooked up the motors or put the car side connector on - that can wait till tomorrow, past my bedtime
...and I was able to rip open the wobbly gear box, I think the hole that holds the metal pin for the middle gear got rounded out - may be in the market for a case if anyone has one lying around
40.42 KB
38.51 KB
46.67 KB
41.43 KB
Super Power Gaucho
Posted - 02/23/2010 :  05:37:46  Show Profile
Which half? I have one that has the cover rounded out but the back half (motor side) is ok (I think, have to confirm). Also I've noticed that the 3A gearboxes take a small black spacer between the GB and the driver. It seems to cut down on wheel wobble.(I haven't figured that one out yet)
Dylan13
Oakmont
Pa
Posted - 02/23/2010 :  06:08:57  Show Profile
I want to say its the motor side but I'd have to double check as well - let me know. I saw the spacers you were talking about, I held onto them but replaced them with a couple flat washers
Super Power Gaucho
wrencher
New Kensington
Pennsylvania
Posted - 02/23/2010 :  13:17:03  Show Profile
i have a whole motor gear box from a 6v barbe jeep if u need it let me know....heres a pic
90.54 KB
Dylan13
Oakmont
Pa
Posted - 02/23/2010 :  14:12:13  Show Profile
90.54 KB
I may have to take you up on that, I'll let you know later tonight - thanks
Super Power Gaucho
Dylan13
Oakmont
Pa
Posted - 02/23/2010 :  20:36:35  Show Profile
Well got the Pink Barbie all wired up and it works - only 1 catch, the gas works like a brake hook the battery up and motors run - hit the gas and they stop, just like a brake....the forward/reverse and high/low switches all work just like they should. I checked the wiring and it matches the one on the left as far a I can tell...I'm guessing its something simple - can someone chime in...thanks
29.62 KB
And I was curious so I took apart the other gearbox for the enforcer and it had a rounded hole for the center gear pin so I guess I'm just going to roll with them and see what happens - thanks taz and wrencher, I'll let you know if that changes
Super Power Gaucho
Edited by - Dylan13 on 02/23/2010 20:45:04
Delhi
Posted - 02/23/2010 :  20:59:22  Show Profile  Visit hotrodtodd's Homepage
Sounds like the plug that goes to the pedal needs flipped end for end.
Bigfoot
Worksite Gator
Driveway Racer
Handy Manny 6v quad
Posted - 02/23/2010 :  21:05:00  Show Profile
Sounds like you installed the wires backwards on the throttle switch.
12vwiz
Mobile
Posted - 02/23/2010 :  21:41:49  Show Profile
I third that! throttle wiring flipped.
My first mod - john deer gator On Hold
Peg Gator LHR shifter Wiring diagram
Big Foot - driver relocation In progress
Edited by - 12vwiz on 02/23/2010 22:01:44
Dylan13
Oakmont
Pa
Posted - 02/24/2010 :  05:10:22  Show Profile
That sounds logical to me Thanks for the votes
...update - ITS ALIVE!!, thanks again for the imput - if the snow holds off today, going to see if we can test run it outside
Super Power Gaucho
Edited by - Dylan13 on 02/24/2010 06:06:50
Posted - 02/24/2010 :  05:37:38  Show Profile
Sorry, forgot to check on that GB. Got too busy tieing down the fort for "the Blizzard of 2010....Part III" I'll try to check tonight before the world stops.
Dylan13
Oakmont
Pa
Posted - 02/24/2010 :  06:04:54  Show Profile
No big deal, I took apart the "good" one and it had the rounded hole for the middle gear peg too so I got a feeling thats the way they are made. I'm just going to run it as is
Super Power Gaucho
Posted - 02/24/2010 :  07:18:59  Show Profile
Now, when they blow up, you have an excuse for 21t #7's
Dylan13
Oakmont
Pa
Posted - 02/27/2010 :  13:53:12  Show Profile
Well they're both done Nothing earth shattering or major bling, just extra speed for the kids I just ended up dropping in the harness from the Big Jake, seemed the easiest since I wasn't going to add the high/low on the Enforcer like I did the Barbie. I did just have to wire in the smaller pedal switch which wasn't a big deal. You can see how the rears on the Enforcer stick out just a bit more with the other drivers
I'll probably end up having to brace up the front and rear like some have done, but we'll see how they perform and go from there
What I did find that may help some other novice guys with the wiring was that when you have to splice in 3 wires, especially between the battery and switch - I used a spare spade connector I had laying around and insulated it like normal with some heat shirk. That way I could crimp the main wire in the normal end and do the split on the spade ends and crimp them, then solder it all. It save me from having to fumble around trying to hold 3 wires together and solder them at the same time This may have been an obvious solution to some but thought the suggestion may help someone else
75.16 KB
55.3 KB
59.68 KB
68.65 KB
60.32 KB
Super Power Gaucho
Edited by - Dylan13 on 02/27/2010 13:56:29
