 Pimp it out
 Plug and Play LED headlight option...NOW INSTALLED
ricam78
The Woodlands
TX
Posted - 01/01/2010 :  21:07:42  Show Profile
**Scroll down to see new installed pics
Anyone try some of these pre-made car dome light panels for headlights? I was thinking this one for the gator, but I am unsure if the depth with work with the stock gator clear lenses. Do you think they would project light at all? They come with peel and stick adhesive on the back already too. There is also a 10% off and free shipping code for this site, so not too bad price wise if they work.
http://www.dinodirect.com/36-LEDs-Car-Ceiling-Dome-Light-Bulb-12V-2-28W-T10-BA9S-Festoon-White-Light.html
John Deere Worksite Gator
Black Jeep Hurricane
Edited by - ricam78 on 01/16/2010 19:46:22
Posted - 01/01/2010 :  21:40:46  Show Profile  Visit CJB's Homepage
If they're close to the same leds I used on this project, you'll love them.
ricam78
The Woodlands
TX
Posted - 01/01/2010 :  21:44:17  Show Profile
They look very similar. Where did you get yours?
Posted - 01/01/2010 :  21:50:29  Show Profile  Visit CJB's Homepage
Made 'em.
I'd bet that one you posted will fit inside the gator lens. The leds are only 2mm high, and I'm assuming the PCB + adhesive tape is also about 2-3mm.
ricam78
The Woodlands
TX
Posted - 01/01/2010 :  21:53:39  Show Profile
Made 'em.
I might order one and give it a try. It says the depth is 5.33 mm, but I think that is cutting it close to one part of the lens. Maybe they are taking the adhesive tape into consideration with that measurement though. Should I worry about the LED's touching the plastic lens at all if it is a snug fit?
Posted - 01/01/2010 :  21:58:21  Show Profile  Visit CJB's Homepage
If they're touching, I imagine they won't diffuse the light as well, but I'm assuming they have a pretty wide viewing angle anyway so I don't know if that'll be much of an issue.
The only thing I'd worry about is heat. I'd have a hard time believing that they would produce enough heat to melt the plastic lens though. You could peel off the adhesive tape if it's too thick and just glue them to the body.
ricam78
The Woodlands
TX
Posted - 01/01/2010 :  22:00:34  Show Profile
Good idea. I will probably order one tonight. Now off to search for a wiring guide now for the lights so I can be sure I hook them up right!
Thanks for the input
Posted - 01/02/2010 :  10:53:28  Show Profile
Red to switch, black to negative.
Another red from positive to the switch.
ricam78
The Woodlands
TX
Posted - 01/02/2010 :  11:25:03  Show Profile
Simple enough, THANKS!
Posted - 01/02/2010 :  11:27:58  Show Profile
No problem, I have a Gator too.
I was going to adapt the $7 floodlights from HF, but this looks better so far.
ricam78
The Woodlands
TX
Posted - 01/02/2010 :  12:03:57  Show Profile
Sounds like a plan. I ordered one today for $11.87 shipped to check and see if it fits. If so, I will let you know. I am assuming I will just need an SPST switch such as this:
http://www.radioshack.com/product/index.jsp?productId=2062523
Then I can crimp the positives from the 2 led lights together, then the 2 negatives and hook it up as described above correct or should I use a terminal block.
Edited by - ricam78 on 01/02/2010 12:32:03
Posted - 01/02/2010 :  13:55:20  Show Profile  Visit CJB's Homepage
That switch will work fine. The terminal block is all a matter of preference. You may want to use one if you plan on doing tail lights or other accessories. It just makes the wiring easier, and easier if you need to take them out temporarily for some reason.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  19:45:05  Show Profile
Just got the one LED board I ordered and hooked it up and it works great!
First thing I did was remove the 3M adhesive pad that came on the back on the lights since it was too deep and didn't allow the lens to fit back over it on the Gator. Then, in order to make sure I didn't mess up up original reflector sheet that came with the Gator in case I ever take out the lights, I traced its outline on some semi rigid construction paper and cut it out as a template. I then took some foil and wrapped the paper I had cut out leaving the shiny side of the foil facing outwards and I taped it to hold it in place on the backside. I cut a small slit in the center of the foil covered template that I made to allow for the wires of the LEDs to pass through. I then covered the back of the circuit board with electrical tape, fed the wires through the slit I cut, and then put some super glue on the elec tape and glued it to the foil covered template. I will be drilling a hole in the center of the headlight body impression to pass the wires through when I install them to stay. I also am thinking of taking a Sharpie silver marker (they have some that are shiny silver) and coloring the white of the LED board so that when they are off the white doesnt stand out as much.
Below are some pics. I will be ordering another one for the other headlight since they worked well. Remember the last pic is with only one headlight since that's all I have right now.
By the way, since they have the little connectors on these lights, you can take them out VERY easily. Just reach under the dash, unhook the small white connectors, take the lens off and then take the LED and template piece out. Put the stock sheet back in and you are good.
Edited by - ricam78 on 01/16/2010 19:54:03
Posted - 01/16/2010 :  19:52:01  Show Profile  Visit CJB's Homepage
Wow. Looks great! I trust you'll be buying the second? Glad to see it worked out as planned.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  19:56:22  Show Profile
Yup, I will order tonight with the 10% coupon they send me from my first order. I also am thinking of taking a Sharpie silver marker (they have some that are shiny silver) and coloring the white of the LED board so that when they are off, the white doesn't stand out as much.
I have too many projects going now. This will be the last thing I order until I catch up!
Posted - 01/16/2010 :  19:58:26  Show Profile  Visit CJB's Homepage
Careful on the marker. Most silver paint things contain some metallic compounds and may cause electrical havoc on your LEDs.
Posted - 01/16/2010 :  19:59:00  Show Profile
I wonder if the 10% off would be more than the shipping?
I'm putting this on my shopping list.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  20:05:32  Show Profile
Actually, I just noticed it was a $1 gift card they sent me. The first one was $11.87 shipped with the 10% coupon below. I also have 11 "dino points" from me first order whatever that is, but they subtracted 70 cents from my total, so his one will was $10.17 shipped. Not too too bad for the simplicity.
coupon code: NEWYEAR201010
10% off for $10+ Items
Edited by - ricam78 on 01/16/2010 20:11:23
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  21:10:50  Show Profile
Scratch that idea then. Should I worry about the foil on the backside?
Posted - 01/16/2010 :  21:17:48  Show Profile  Visit CJB's Homepage
Are there resistors on the back?
My suggestion would be to apply conformal coating first, then put on your foil & silver paint.
You can pick up some acryllic conformal coating at any electronics shop, or online. At work, I use Fine-L-Kote AR.
http://www.altex.com/Techspray-Fine-L-Kote%C3%A2%E2%80%9E%C2%A2-AR-Acrylic-Conformal-Coating-P145963.aspx
It's a little pricey, but this will last you for your whole PW modding career. Two or three coats, and you can run these babies underwater if you wanted to.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  21:36:19  Show Profile
Convenient for me is that I am always at Altex since I work around the corner and am in IT. This is the silver Sharpie Metallic marker:
http://www.sharpie.com/enUS/Product/Sharpie_Metallic_Fine_Point_Permanent_Marker.html
Here is the MSDS on it, does this tell me what I need to know about its stability and using it on the panel?
http://www.sharpie.com/img/compel/Q2EoiSKj3xo1aABZQeFh0ExWcX_qXskn/SharpieMetallic.pdf
Posted - 01/16/2010 :  21:48:14  Show Profile  Visit CJB's Homepage
The MSDS lists it as 'pigment'. It does not say whether or not it's a metallic based pigment. You can try it, and see if it affects the leds or not. I imagine the dielectric properties of the pigments wouldn't be enough to 'kill' the LEDs, but rather dim or flicker them if at all.
Another option would be clear nail polish on the solder joints...
EDIT: and the vias (metal holes)
Edited by - CJB on 01/16/2010 21:51:02
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  22:04:23  Show Profile
Nothing can ever be simple! I might try and use a white background instead of the reflective on as that would make the board and LEDs blend really well when not on.
Posted - 01/16/2010 :  22:09:34  Show Profile  Visit CJB's Homepage
You're so picky.
Just clear coat it and sharpie it up. Acryllic clear coat paint would so the same a conformal coating I would assume.
If you're going to do it, DO IT RIGHT.
A customer I work with at my job has a QA inspector that has a favorite saying:
"Every job is a portrait of the person who made it. Autograph your work with excellence."
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  22:19:04  Show Profile
You're so picky.
I know I know. I just ripped the foil off and left it white and it didnt look bad at all, but not as good as it would with the foil and some sharpie work. I will do it right as I alrady have to wait a week or more for the other light to come in anyway.
In the meantime, I have to get the new tires on the gator, install 2nd battery adn charge port on Gator, pressure wash the hurricane parts, paint the hurricane parts, add lights to the hurricane, re-assemble the hurricane and then sell my KFX Ninja and Super 6 Dora Jeep.
Posted - 01/16/2010 :  22:21:32  Show Profile  Visit CJB's Homepage
Sounds like you have your work cut out for you.
When you pressure wash a PW, be careful. They like to run away from you. Then you have to hold it down with your foot, and then you get all wet.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  22:27:23  Show Profile
I was thinking of bringing a laundry basket with me. Put the smaller parts in there and go to town on them. Some might climb out with the pressure but it wont be as bad.
Posted - 01/16/2010 :  22:29:36  Show Profile  Visit CJB's Homepage
Good idea. Wish I though of that before I had to throw my shoes in the dryer.
ricam78
The Woodlands
TX
Posted - 01/16/2010 :  22:35:24  Show Profile
I would have ended up the same as you, but someone warned me that it was messy on another thread, so I have been thinking of a way to avoid it ever since.
Jono11111
Florissant
MO
Posted - 02/08/2010 :  12:10:44  Show Profile
So according to your love of that rectangle would you recommend this item from the same people?
http://www.dinodirect.com/12-LED-Car-Interior-Dome-Door-Box-Light-Bulb-40227.html
Should I do that or do the Harbor Freight light which is probably dim?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95799
Posted - 02/08/2010 :  12:16:02  Show Profile
I can tell you that the HF lighting unit is NOT dim. It's pretty blinding, actually.
The dome light may be better for this application though - it's flat, it may even fit without drilling out the lights, and it wouldn't blind the kids looking into the headlights
Posted - 02/08/2010 :  14:00:03  Show Profile
I would think a dome light (used for a small area..car) would be dim compared to a spotlight. Thats just me I do have 4 of the HF ones.
Posted - 02/08/2010 :  14:19:10  Show Profile
The big question is really:
Are these used as actual headlights, that is, at night, in a dark area?
If they're just for show, and a little visibility, those dome lights should be fine.
If you're actually expecting the kids to drive in the dark, the HF spotlights light up trees they won't get to for 30 seconds
ricam78
The Woodlands
TX
Posted - 02/08/2010 :  16:58:20  Show Profile
I actually have 2 harbor light spots I bought to use on a Hurrican project, but scrapped the idea and went for single pre-wired Oziniums. I still need to bring these back, but I plugged it in in my garage where the square dome was plugged in to show you the difference. This is only one spot and one dome light. The dome spreads more as you can see and honestly is way brighter IMO.
HF SPOT
DINO DIRECT DOME
Posted - 02/08/2010 :  17:00:52  Show Profile
Wow!
Looks like I'm going to be ordering a few Ozmiums, and a couple dome lights, and setting up a test bench.
ricam78
The Woodlands
TX
Posted - 02/08/2010 :  18:25:31  Show Profile
Wow!
The Oziniums are the least bright of the 3, but they were the easiest to install in the jeep. I can probably get a pic of that in the same spot tomorrow night if you need.
Posted - 02/08/2010 :  19:42:13  Show Profile
I didnt think the HF lights were that great but hey you get wire a fuse and a board full of led's for a cheap price.
WOW on that dome light!
ricam78
The Woodlands
TX
Posted - 02/08/2010 :  20:09:56  Show Profile
True of the HF setup. I just was too lazy to tear them apart!
I threw both dome lights in and took some pics just now with the same camera and settings as the HF spot I took above. One of the domes is a blue and one is a white (they are sending me another and when I get it they will remain in the Gator)
Posted - 02/09/2010 :  21:17:33  Show Profile
Just a thought - the round light only has 12 LED's, and the rectangular one has 36.
Assuming the actual LED's are similar, if not the same, the rectangular ones should be three times as bright.
mrbandit
Goldsboro
Posted - 02/10/2010 :  06:46:49  Show Profile  Visit mrbandit's Homepage
Rather then sharpie or painting the board you could just get some cheap silver pin striping from your local auto parts supplier. They come in different widths and would cover the area nicely without causing electrical issues. Just a thought.
ricam78
The Woodlands
TX
Posted - 02/10/2010 :  07:07:49  Show Profile
Good idea. What I did was use Electricians bundling tape which is more of a silver than chrome, but I knew it would not have any "metallics" in it which would maybe short out the board. I laid a piece out on a cutting board and used a razor knife to cut it into strips.
MustangFreak
San Antonio
Posted - 02/11/2010 :  23:12:24  Show Profile  Visit MustangFreak's Homepage  Send MustangFreak a Yahoo! Message
Ok, i just read all this... and then re-read.... so the almost blinding lights in the gator, are these 12 LED car dome lights?
They are a little pricey... but if they light up like that, than I think they are well worth the price... that is exactly what I was looking for.
I think I am still going to use some of the oznium superflux in the Mustang though, just because they will be super easy to install, and look more realistic during the day.
I'm not an addict, addicts have the potential to quit.
ricam78
The Woodlands
TX
Posted - 02/12/2010 :  06:11:48  Show Profile
The lights I put on the gator are in the first link. They are the square 36 LED boards and with the coupons and dinocash, they were like $11 each.
MustangFreak
San Antonio
Posted - 02/12/2010 :  23:07:57  Show Profile  Visit MustangFreak's Homepage  Send MustangFreak a Yahoo! Message
Ok, I guess somehow I overlooked the first link.... those lights are really sweet!
So, are these the correct dimensions? 1.97 in x 1.38 in x 0.21 in
Its just hard to believe that something so small can produce so much light. I might have to make a flashlight out of one, using a 4ah or smaller battery.
ricam78
The Woodlands
TX
Posted - 02/13/2010 :  07:46:26  Show Profile
yes, those outer dimensions are correct. I can't confirm the depth because I pulled off the 3M adhesive backing that came on it since it was a padded backing that was too deep for the gator lenses.
rmfroyd
Posted - 02/15/2010 :  08:53:46  Show Profile
I am assuming that the resistors are already installed on the board?
ricam78
The Woodlands
TX
Posted - 02/15/2010 :  08:58:20  Show Profile
yup, just hook it to a 12v power source and you are good.
DinoDirect
Palo Alto
United Kingdom
Posted - 03/17/2010 :  02:51:05  Show Profile  Visit DinoDirect's Homepage
Hello everyone,
This is DinoDirect.com official account. We tracked several orders were brought from modifiedpowerwheels.com. We noticed this coupon NewYear2010 has been expired, and we are pleased to provide you with our 10% exclusive coupon code: Spring2010.
For you, we have other good quality LED headlights.
http://www.dinodirect.com/Car-Ceiling-Dome-Light-CT-691/affid-70.html
Posted - 03/17/2010 :  04:27:25  Show Profile
^^^ Huh, well how bout that ^^^
ricam78
The Woodlands
TX
Posted - 03/17/2010 :  06:03:30  Show Profile
Hey 10% is 10% right! Thanks Dino
Posted - 03/17/2010 :  13:16:01  Show Profile
Yeah, that's more personal attention than I would have expected.
Thanks Dino!
